Ir para o conteúdo principal
iBook G3 14" DC-In Board Replacement
O que você precisa
  1. iBook G3 14" DC-In Board Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Pergunte ao FixBot
    Comentar
  2. iBook G3 14" DC-In Board Replacement, Keyboard: passo 2, imagem 1 %32
    • Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    Pergunte ao FixBot
    Comentar
  3. iBook G3 14" DC-In Board Replacement: passo 3, imagem 1 %32
    • If your computer does not have an AirPort card installed, skip to the RAM shield removal step.
    • Push the wire clasp toward the AirPort card and pull it up to free it from the RAM shield.
    Pergunte ao FixBot
    Comentar
  4. iBook G3 14" DC-In Board Replacement: passo 4, imagem 1 %32
    • Grasp the clear plastic tab on the AirPort card and pull toward the right.
    Pergunte ao FixBot
    Comentar
  5. iBook G3 14" DC-In Board Replacement: passo 5, imagem 1 %32
    • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
    Pergunte ao FixBot
    Comentar
  6. iBook G3 14" DC-In Board Replacement: passo 6, imagem 1 %32
    • Remove the two Phillips screws that secure the RAM shield.
    Pergunte ao FixBot
    Comentar
  7. iBook G3 14" DC-In Board Replacement: passo 7, imagem 1 %32
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    Pergunte ao FixBot
    Comentar
  8. iBook G3 14" DC-In Board Replacement: passo 8, imagem 1 %32
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    Pergunte ao FixBot
    Comentar
  9. iBook G3 14" DC-In Board Replacement, Lower Case: passo 9, imagem 1 %32
    • Use a pin to remove the three rubber feet from the lower case.
    Pergunte ao FixBot
    Comentar
  10. iBook G3 14" DC-In Board Replacement: passo 10, imagem 1 %32
    • Remove the three newly-revealed Phillips screws.
    Pergunte ao FixBot
    Comentar
  11. iBook G3 14" DC-In Board Replacement: passo 11, imagem 1 %32
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    Pergunte ao FixBot
    Comentar
  12. iBook G3 14" DC-In Board Replacement: passo 12, imagem 1 %32
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The screw in the center is shorter than the other two.
    Pergunte ao FixBot
    Comentar
  13. iBook G3 14" DC-In Board Replacement: passo 13, imagem 1 %32
    • Remove the two Phillips screws on either side of the battery contacts.
    Pergunte ao FixBot
    Comentar
  14. iBook G3 14" DC-In Board Replacement: passo 14, imagem 1 %32
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
    Pergunte ao FixBot
    Comentar
  15. iBook G3 14" DC-In Board Replacement: passo 15, imagem 1 %32
    • There is a slot on the wall of the battery compartment that locks the lower case in place.
    • Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    Pergunte ao FixBot
    Comentar
  16. iBook G3 14" DC-In Board Replacement: passo 16, imagem 1 %32
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case.
    • Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    Pergunte ao FixBot
    Comentar
  17. iBook G3 14" DC-In Board Replacement: passo 17, imagem 1 %32
    • Continue to run the spudger around the front, right corner.
    • There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
    Pergunte ao FixBot
    Comentar
  18. iBook G3 14" DC-In Board Replacement: passo 18, imagem 1 %32
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you.
    • Pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
    Pergunte ao FixBot
    Comentar
  19. iBook G3 14" DC-In Board Replacement: passo 19, imagem 1 %32
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    Pergunte ao FixBot
    Comentar
  20. iBook G3 14" DC-In Board Replacement, Upper Case: passo 20, imagem 1 %32
    • All of the screws in the following step have small heads - the screws with larger heads hold the bottom shield on.
    • Remove the following 9 screws on the bottom of the computer:
    • Three 3 mm Phillips around the battery compartment.
    • Three 5 mm Phillips on the left and bottom edges.
    • Three 14.5 mm Phillips on the top and right edges (you may have to peel back the foil tape to reveal the screw near the security lock slot).
    Pergunte ao FixBot
    Comentar
  21. iBook G3 14" DC-In Board Replacement: passo 21, imagem 1 %32
    • Turn over the computer and open it.
    • Pry up the magnet covering a Phillips screw near the middle of the computer.
    • You may need to peel back the serial number sticker to access the magnet.
    Pergunte ao FixBot
    Comentar
  22. iBook G3 14" DC-In Board Replacement: passo 22, imagem 1 %32
    • Remove the following 3 screws on the edges of the keyboard area:
    • Two 6 mm Phillips underneath the keyboard area.
    • One 9 mm Phillips above the keyboard area.
    • On some models, there may also be a screw under the magnet you just removed. If so, remove the screw at this point.
    Pergunte ao FixBot
    Comentar
  23. iBook G3 14" DC-In Board Replacement: passo 23, imagem 1 %32
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • After disengaging the locking bar, slide the cable out of the connector.
    Pergunte ao FixBot
    Comentar
  24. iBook G3 14" DC-In Board Replacement: passo 24, imagem 1 %32
    • Loosen the trackpad connector by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the connector.
    Pergunte ao FixBot
    Comentar
  25. iBook G3 14" DC-In Board Replacement: passo 25, imagem 1 %32
    • Use a straightened paperclip to open the optical drive tray, and pull it out about halfway.
    Pergunte ao FixBot
    Comentar
  26. iBook G3 14" DC-In Board Replacement: passo 26, imagem 1 %32
    • Don't lift the upper case off the computer yet as there are still two cables left to disconnect.
    • Lift the upper case from the left side and use your other hand to pull out the right side in order to clear the power receptacle.
    Pergunte ao FixBot
    Comentar
  27. iBook G3 14" DC-In Board Replacement: passo 27, imagem 1 %32
    • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board.
    • Using your fingernails or a dental pick, carefully pry the connector from its socket.
    • Make sure you are pulling only on the connector and not on the socket.
    Pergunte ao FixBot
    Comentar
  28. iBook G3 14" DC-In Board Replacement: passo 28, imagem 1 %32
    • Lift the upper case off completely and disconnect the red and black speaker cable from the logic board.
    Pergunte ao FixBot
    Comentar
    • Peel back the yellow tape and foil shielding.
    Pergunte ao FixBot
    Comentar
  29. iBook G3 14" DC-In Board Replacement: passo 30, imagem 1 %32
    • Remove the following 10 screws:
    • One 5 mm Phillips at the upper, right corner of the battery compartment.
    • Nine 6 mm Phillips scattered around the shield.
    • Lift the bottom shield off.
    Pergunte ao FixBot
    Comentar
  30. iBook G3 14" DC-In Board Replacement, DC-In Board: passo 31, imagem 1 %32
    • Remove the yellow tape securing the DC cable to the metal framework and disconnect the DC cable from the logic board.
    Pergunte ao FixBot
    Comentar
  31. iBook G3 14" DC-In Board Replacement: passo 32, imagem 1 %32
    • Remove the single Phillips screw from the DC-In board.
    • Pull the DC-In board out of the computer, pulling the DC cable through the convenient slot beneath the board.
    Pergunte ao FixBot
    Comentar
Conclusão
Documentos anexados
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 53
Ao todo: 9,564
