Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Install an original Airport 802.11b card internally.
O que você precisa
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
17 outras pessoas executaram este guia.
