Introdução
This guide will show you the steps on how to replace your M.2 NVMe Drive in your iBUYPOWER Trace 4 9310 desktop. The iBUYPOWER Trace 4 9310 comes with 2 SATA ports and 1 M.2 NVMe Drive port.
This guide can be completed within a few minutes, and you only need a small Phillips head screwdriver.
As a precaution, unplug and turn off your computer before working on it.
O que você precisa
Lay the desktop on its side with the glass panel facing up.
Remove the single screw.
4 outras pessoas executaram este guia.
Um comentário
Thank you, Kilie, for the clear step-by-step instructions, together with pictures, for NVMe SSD installation.
George
