Ir para o conteúdo principal
hp pavilion 15-cc023cl Motherboard Replacement
O que você precisa
  1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: passo 1, imagem 1 %32 hp pavilion 15-cc023cl Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Motherboard Replacement: passo 2, imagem 1 %32
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Motherboard Replacement: passo 3, imagem 1 %32 hp pavilion 15-cc023cl Motherboard Replacement: passo 3, imagem 2 %32
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Motherboard Replacement: passo 4, imagem 1 %32 hp pavilion 15-cc023cl Motherboard Replacement: passo 4, imagem 2 %32
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Motherboard Replacement, Hard Drive: passo 5, imagem 1 %32
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Motherboard Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Motherboard Replacement: passo 7, imagem 1 %32
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Motherboard Replacement: passo 8, imagem 1 %32
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Motherboard Replacement: passo 10, imagem 1 %32 hp pavilion 15-cc023cl Motherboard Replacement: passo 10, imagem 2 %32
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Motherboard Replacement: passo 11, imagem 1 %32
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Motherboard Replacement: passo 12, imagem 1 %32
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Motherboard Replacement: passo 13, imagem 1 %32
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Motherboard Replacement: passo 14, imagem 1 %32 hp pavilion 15-cc023cl Motherboard Replacement: passo 14, imagem 2 %32 hp pavilion 15-cc023cl Motherboard Replacement: passo 14, imagem 3 %32
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Motherboard Replacement: passo 15, imagem 1 %32 hp pavilion 15-cc023cl Motherboard Replacement: passo 15, imagem 2 %32
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Motherboard Replacement: passo 16, imagem 1 %32
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Motherboard Replacement: passo 17, imagem 1 %32
    • Disconnect SD and USB card cable.
Conclusão
2 comentários
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
richeydale67 - Responder
How can i get this model motherboard
Adeyinka Alasi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 1,488
