Pular para o conteúdo principal
Ajuda
Canon PowerShot A75 Casing Replacement
This guide will walk you through the steps to take the casing off of your camera.
  • Autor: Andrew Elliott
  • Tempo estimado: 2 - 5 minutos
  • Dificuldade: Fácil
Use this guide to replace the Canon Powershot A75's casing.
Seções
Ferramentas
Passo 1 Casing  ¶
Remove the three 2.5mm screws on the bottom of the camera.
Passo 1 Casing  ¶
  • Remove the three 2.5mm screws on the bottom of the camera.
Passo 2  ¶
Remove the 3.8mm screw underneath the flap that covers the A/V port.
Passo 2  ¶
  • Remove the 3.8mm screw underneath the flap that covers the A/V port.
Passo 3  ¶
Remove the 2.4mm screw located underneath the cover of the memory card slot. Remove the 2.4mm screw located underneath the cover of the memory card slot.
Passo 3  ¶
  • Remove the 2.4mm screw located underneath the cover of the memory card slot.
Passo 4  ¶
Open the memory card slot by sliding it laterally until you hear a click. Remove the 5.9mm screw in the upper corner of the memory card slot.
Passo 4  ¶
  • Open the memory card slot by sliding it laterally until you hear a click.
  • Remove the 5.9mm screw in the upper corner of the memory card slot.
Passo 5  ¶
Remove the two 4.1mm screws at the bottom of the battery flap.
Passo 5  ¶
  • Remove the two 4.1mm screws at the bottom of the battery flap.
Passo 6  ¶
Lift the shutter button and speaker part from the top of the camera. DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
Passo 6  ¶
  • Lift the shutter button and speaker part from the top of the camera.
  • DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
Passo 7  ¶
Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
Passo 7  ¶
  • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
Passo 8  ¶
Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
Passo 8  ¶
  • Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
Passo 9  ¶
Separate the back casing and front casing of the camera using your hands. Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force. Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
Passo 9  ¶
  • Separate the back casing and front casing of the camera using your hands.
  • Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
Passo 10  ¶
On the front of the camera, press the button on the lower left of the lens. Twist the outer lens casing counter-clockwise and slide it out. Twist the outer lens casing counter-clockwise and slide it out.
Passo 10  ¶
  • On the front of the camera, press the button on the lower left of the lens.
  • Twist the outer lens casing counter-clockwise and slide it out.
Passo 11  ¶
Take off the front casing. There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together. There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
Passo 11  ¶
  • Take off the front casing.
  • There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
