Pular para o conteúdo principal
Ajuda
Dell Photo Printer 540 LCD Panel Replacement
Melhor Introdução
Melhor Introdução
Melhore este guia, completando ou revendo a sua introdução.
If your LCD Panel is cracked or not displaying anything this guide will assist you in replacing it.
  • Autor: Ashley Lopez
  • Tempo estimado: 15 minutos
  • Dificuldade: Fácil
Passo 1 LCD Panel  ¶
Locate the data ribbon that connects the LCD panel to the mother board.
Passo 1 LCD Panel  ¶
  • Locate the data ribbon that connects the LCD panel to the mother board.
  • Carefully unclip the ribbon from the mother board.
  • Separate top cover from bottom base and flip upright so that the LCD panel is facing up for the next step
Passo 2  ¶
Slide the LCD panel out and away from the printer case. Hold bottom of LCD panel and lift the screen 70 degrees. Set the screen face down for the next step
Passo 2  ¶
  • Slide the LCD panel out and away from the printer case.
  • Hold bottom of LCD panel and lift the screen 70 degrees. Set the screen face down for the next step
Passo 3  ¶
Use a Phillips 00 screwdriver to remove the four 5.4 mm screws behind where the LCD screen is.
Passo 3  ¶
  • Use a Phillips 00 screwdriver to remove the four 5.4 mm screws behind where the LCD screen is.
Passo 4  ¶
You can now separate the individual pieces from each other, allowing the screen to be accessible to replace.
Passo 4  ¶
  • You can now separate the individual pieces from each other, allowing the screen to be accessible to replace.
