Pular para o conteúdo principal
Ajuda
MacBook Pro 15" Unibody Late 2008 and Early 2009 Lower Case Replacement
Replace the aluminum bottom case in a MacBook Pro Unibody.
Passo 1 Lower Case  ¶
Remove the following eight screws securing the lower case to the chassis:
  • Remove the following eight screws securing the lower case to the chassis:
  • One 5.4 mm Phillips screw.
  • Three 14 mm Phillips screws.
  • Four 3.5 mm Phillips screws.
Passo 2  ¶
Using both hands, lift and remove the lower case off the upper case.
Passo 2  ¶
  • Using both hands, lift and remove the lower case off the upper case.
