Pular para o conteúdo principal
Ajuda
Nexus One Motherboards Replacement
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
This guide is for installing the upper and lower motherboards on the Nexus One.
  • Autor: Niklas Johnson
  • Tempo estimado: 45 minutos - 1 hora
  • Dificuldade: Moderado
Passo 1 Motherboards  ¶
Insert the spudger under the connector. Push the spudger up and twist to release the connector.
  • Insert the spudger under the connector.
  • Push the spudger up and twist to release the connector.
  • Repeat for the next connector.
Passo 2  ¶
Push on the USB port to expose the black connector. Use the spudger to pry the connector upwards. Use the spudger to pry the connector upwards.
Passo 2  ¶
  • Push on the USB port to expose the black connector.
  • Use the spudger to pry the connector upwards.
Passo 3  ¶
Place the spugder under the antenna connector. Pry connector up vertically.
Passo 3  ¶
  • Place the spugder under the antenna connector.
  • Pry connector up vertically.
Passo 4  ¶
Insert the spudger into tab above the camera. Slide upwards until the board detaches from the case. Slide upwards until the board detaches from the case.
Passo 4  ¶
  • Insert the spudger into tab above the camera.
  • Slide upwards until the board detaches from the case.
Passo 5  ¶
Press the pointed tip of the spudger into the space below the button assembly.
Passo 5  ¶
  • Press the pointed tip of the spudger into the space below the button assembly.
  • Wiggle the spudger tip towards the outside of the button.
  • The button assembly is under some tension and may fly off.
Passo 6  ¶
Push the pointed tip of the spudger into the base of the side button board.
Passo 6  ¶
  • Push the pointed tip of the spudger into the base of the side button board.
  • Lift up, the board will disconnect from the case.
Passo 7  ¶
Push on the lower motherboard until it slides under the case support. The motherboard assembly comes out as a single piece. Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
Passo 7  ¶
  • Push on the lower motherboard until it slides under the case support.
  • The motherboard assembly comes out as a single piece.
  • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
