Pular para o conteúdo principal
Ajuda
Sansa e260R Front Panel Replacement
Removing a broken case
Passo 1 Front Panel  ¶
Remove the four 1.5mm screws on the inner casing of the device.
  • Remove the four 1.5mm screws on the inner casing of the device.
  • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
Passo 2  ¶
Flip the device so that the front is facing you.
Passo 2  ¶
  • Flip the device so that the front is facing you.
  • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
Passo 3  ¶
Pull the front cover away from the rest of the device. Pull the front cover away from the rest of the device.
Passo 3  ¶
  • Pull the front cover away from the rest of the device.
