Pular para o conteúdo principal
Ajuda
MacBook Unibody Model A1278 Logic Board Replacement
  • Autor: Walter Galan
  • Tempo estimado: 2 - 4 horas
  • Dificuldade: Difícil
This motherboard includes all ports on the left side.
Seções
Ferramentas
Passo 1 Logic Board  ¶
Disconnect the DC-In Board from the logic board by pulling its connector straight away from the socket on the logic board.
  • Disconnect the DC-In Board from the logic board by pulling its connector straight away from the socket on the logic board.
Passo 2  ¶
Use the flat end of a spudger to pry the left speaker connector up off the logic board.
Passo 2  ¶
  • Use the flat end of a spudger to pry the left speaker connector up off the logic board.
Passo 3  ¶
Use the flat end of a spudger to pry the microphone connector up off the logic board.
Passo 3  ¶
  • Use the flat end of a spudger to pry the microphone connector up off the logic board.
Passo 4  ¶
Use the flat end of a spudger to separate the adhesive securing the left speaker assembly to the logic board.
Passo 4  ¶
  • Use the flat end of a spudger to separate the adhesive securing the left speaker assembly to the logic board.
Passo 5  ¶
Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
Passo 5  ¶
  • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Passo 6  ¶
After the RAM chip has popped up, pull it straight out of its socket.
Passo 6  ¶
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
  • When reinstalling your logic board, don't forget to apply a new layer of thermal paste.
