Pular para o conteúdo principal
Ajuda
Técnica: iFixit 26 Bit Driver Kit Technique for Removing Bits
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
Simple trick to help remove the bits from the tightly packed kit's storage area.
  • Autor: aaronmiller
  • Tempo estimado: 1 minuto
  • Dificuldade: Muito fácil
Consider this a meta-guide...that is, a guide that enables other guides. Before you remove any screws, you need to use the right bit, but getting those out of the tightly packed storage area and into your driver can be a chore in itself.
Ferramentas
Passo 1 iFixit 26 Bit Driver Kit Technique for Removing Bits  ¶
Note how challenging it is to remove a required bit from the kit. Argh!
  • Note how challenging it is to remove a required bit from the kit. Argh!
Passo 2  ¶
Find yourself a rubber band...
Passo 2  ¶
  • Find yourself a rubber band...
Passo 3  ¶
Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
Passo 3  ¶
  • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
Passo 4  ¶
Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
Passo 4  ¶
  • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
