Pular para o conteúdo principal
Ajuda
Sony Ericsson s710a Battery Replacement
Replace an old or damaged battery.
  • Autor: Mike
  • Tempo estimado: 2 minutos
  • Dificuldade: Muito fácil
This guide will show you how to install a battery in the Sony Ericsson s710a. It can be used if the current battery is missing or faulty and needs to be replaced.
Partes relevantes
Passo 1 Battery  ¶
Remove the back cover by sliding it off.
Passo 1 Battery  ¶
  • Remove the back cover by sliding it off.
Passo 2  ¶
Once the back cover is removed, pull out the battery using your finger as shown.
Passo 2  ¶
  • Once the back cover is removed, pull out the battery using your finger as shown.
Passo 3  ¶
The battery can now be replaced if desired.
Passo 3  ¶
  • The battery can now be replaced if desired.
  • The battery is a 780 mAh rechargeable Lithium Ion battery.
