Pular para o conteúdo principal
Ajuda
Samsung Glyde Motherboard Replacement
Fotos de ação
Fotos de ação
Seja um herói em ação! Este guia precisa de imagens que melhor demonstrem como executar ações específicas.
Melhor Introdução
Melhor Introdução
Melhore este guia, completando ou revendo a sua introdução.
Faltando detalhes
Faltando detalhes
Alguns dos detalhes deste guia estão faltando. Ajude os usuários adicionando ferramentas, dificuldades, ou tempo.
This guide will provide a step by step procedure for installing the motherboard
  • Autor: Stephen
  • Dificuldade: Moderado
Seções
Ferramentas
Passo 1 Motherboard  ¶
Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together. Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
  • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
Passo 2  ¶
Use a  plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
Passo 2  ¶
  • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
  • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
  • Using your fingers, take the case off.
Passo 3  ¶
The green film above the camera is the camera connector to the motherboard. Use a plastic opening tool to disconnect the camera connector.
Passo 3  ¶
  • The green film above the camera is the camera connector to the motherboard.
  • Use a plastic opening tool to disconnect the camera connector.
Passo 4  ¶
The golden film connector connects the keyboard to the motherboard. Use a plastic opening tool to disconnect the keyboard connector.
Passo 4  ¶
  • The golden film connector connects the keyboard to the motherboard.
  • Use a plastic opening tool to disconnect the keyboard connector.
Passo 5  ¶
The circular connector holds the motherboard in place. Using a plastic opening tool, disconnect the circular connector.
Passo 5  ¶
  • The circular connector holds the motherboard in place.
  • Using a plastic opening tool, disconnect the circular connector.
Passo 6  ¶
There is a LCD connector underneath the motherboard. Gently lift the far edge of the motherboard upwards toward the center of the phone. Using a plastic opening tool, disconnect the LCD connector.
Passo 6  ¶
  • There is a LCD connector underneath the motherboard.
  • Gently lift the far edge of the motherboard upwards toward the center of the phone.
  • Using a plastic opening tool, disconnect the LCD connector.
Passo 7  ¶
After disconnecting the four connectors, gently lift the motherboard up with your fingers. Place the motherboard in a secure area.
Passo 7  ¶
  • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
  • Place the motherboard in a secure area.
