Pular para o conteúdo principal
Ajuda
iPhone 4S Battery Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
Replace the battery on your iPhone 4S.
  • Autor: Walter Galan
  • Tempo estimado: 10 - 30 minutos
  • Dificuldade: Moderado
Replacing the battery on the iPhone 4S requires minimal disassembly. If your battery is swollen, take appropriate precautions.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Ferramentas (continuação)
Partes relevantes
Passo 1 Battery  ¶
Remove the following screws securing the battery connector to the logic board: One 1.7 mm Phillips screw
Passo 1 Battery  ¶
  • Remove the following screws securing the battery connector to the logic board:
  • One 1.7 mm Phillips screw
  • One 1.5 mm Phillips screw
Passo 2  ¶
Carefully push the pressure contact away from the battery connector until it slides free from its position. Remove the pressure contact. Remove the pressure contact.
Passo 2  ¶
  • Carefully push the pressure contact away from the battery connector until it slides free from its position.
  • Remove the pressure contact.
Passo 3  ¶
Use a plastic opening tool to gently pry up the battery connector from its socket on the logic board. Place the tip of the tool between the loudspeaker enclosure and the metal cover of the connector, and lift the bottom edge of the connector first. The battery connector comes off vertically from the logic board. Do not apply force sideways.
Passo 3  ¶
  • Use a plastic opening tool to gently pry up the battery connector from its socket on the logic board.
  • Place the tip of the tool between the loudspeaker enclosure and the metal cover of the connector, and lift the bottom edge of the connector first.
  • The battery connector comes off vertically from the logic board. Do not apply force sideways.
  • Be careful not to pry at the battery connector socket itself, or it may detach from the logic board. There are four very small solder points awaiting this mistake!
Passo 4  ¶
Before you reattach the battery connector during reinstallation, carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector. Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
Passo 4  ¶
  • Before you reattach the battery connector during reinstallation, carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector.
  • Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
Passo 5  ¶
Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone. Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
Passo 5  ¶
  • Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
  • Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
Passo 6  ¶
Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone. Be careful not to pull the plastic pull tab too hard as it can be ripped off very easily.
Passo 6  ¶
  • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
  • Be careful not to pull the plastic pull tab too hard as it can be ripped off very easily.
  • Remove the battery.
  • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the ribbon cable.
  • If your replacement battery came with an uncreased cable, carefully crease the cable into the proper shape before installing the battery into the phone.
  • While installing the replacement battery, temporarily connect the battery connector to the phone to ensure proper alignment. Once the battery is glued in place, disconnect the battery connector.
  • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
