Pular para o conteúdo principal
Ajuda
Disassembling Microtek ScanMaker 5900 Device Lid
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
This guide will show you how to take off the scanner's lid.
  • Autor: Taylor Nesheim
  • Tempo estimado: 2 - 3 minutos
  • Dificuldade: Fácil
This guide aims to teach the owner of a Microtek Scanmaker 5900 how to remove the lid of the device.
Passo 1 Remove serial port connection  ¶
Loosen the screws on the serial port by turning them counter clockwise by hand. After loosening the screws, pull the serial port out. After loosening the screws, pull the serial port out.
  • Loosen the screws on the serial port by turning them counter clockwise by hand.
  • After loosening the screws, pull the serial port out.
Passo 2 Remove Lid  ¶
Lift lid to its vertical position. Pull lid straight up to remove it from the scanner. Pull lid straight up to remove it from the scanner.
  • Lift lid to its vertical position.
  • Pull lid straight up to remove it from the scanner.
