Pular para o conteúdo principal
Ajuda
Dell Inspiron 530 Power Supply Replacement
Removing the computer's power supply unit
  • Autor: Doug Howe
  • Tempo estimado: 5 - 7 minutos
  • Dificuldade: Moderado
This guide will demonstrate removing the computer's power supply.
Seções
Ferramentas
Passo 1 Power Supply  ¶
Locate the power supply in upper-back corner of the case.
  • Locate the power supply in upper-back corner of the case.
Passo 2  ¶
Remove the two power cables from the motherboard.
Passo 2  ¶
  • Remove the two power cables from the motherboard.
Passo 3  ¶
Remove the power cables from the CD/DVD drive and hard drive.
Passo 3  ¶
  • Remove the power cables from the CD/DVD drive and hard drive.
Passo 4  ¶
Locate and remove the four Philips #0 8.9 mm screws on the outside of the case.
Passo 4  ¶
  • Locate and remove the four Philips #0 8.9 mm screws on the outside of the case.
Passo 5  ¶
Gently remove the power supply from the case.
Passo 5  ¶
  • Gently remove the power supply from the case.
