Pular para o conteúdo principal
Ajuda
HP Photosmart c3180 Main Circuit Board Replacement
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
Replacing a faulty main circuit board.
  • Autor: Jim
  • Tempo estimado: 20 - 30 minutos
  • Dificuldade: Difícil
Passo 1 Main Circuit Board  ¶
Set aside the feed roller assembly. Push down on the tab that is on the power and USB back panel and then away from the printer to remove the power and USB back panel. Push down on the tab that is on the power and USB back panel and then away from the printer to remove the power and USB back panel.
  • Set aside the feed roller assembly.
  • Push down on the tab that is on the power and USB back panel and then away from the printer to remove the power and USB back panel.
Passo 2  ¶
Remove the two T10 12mm Torx screws from the main circuit board. Remove the two T10 12mm Torx screws from the main circuit board.
Passo 2  ¶
  • Remove the two T10 12mm Torx screws from the main circuit board.
Passo 3  ¶
Remove the main circuit board by gently lifting it up from the back and pulling away from the front of the printer.
Passo 3  ¶
  • Remove the main circuit board by gently lifting it up from the back and pulling away from the front of the printer.
  • Be careful not to lift to fast, as doing so can cause damage to the main circuit board.
