Pular para o conteúdo principal
Ajuda
iBook G4 12" 1.33 GHz Battery Replacement
Changing the battery is easy -- all you need is a coin.
Passo 1 Battery  ¶
Lay your iBook upside down on a flat surface. Use a coin to rotate the battery locking screw 90 degrees clockwise.
Passo 1 Battery  ¶
  • Lay your iBook upside down on a flat surface.
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
