Pular para o conteúdo principal
Ajuda
iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement
Follow to access hard drive, optical drive, or components behind carrier.
  • Autor: Courtney
  • Tempo estimado: 30 minutos
  • Dificuldade: Moderado
Passo 1 Drive Carrier Assembly  ¶
Remove the 2 torx 10mm screws on the EMI shield Carefully remove shield and copper tape Carefully remove shield and copper tape
  • Remove the 2 torx 10mm screws on the EMI shield
  • Carefully remove shield and copper tape
Passo 2  ¶
Remove the 4 10mm torx screws attatched to the drive carrier. The drive carrier includes optical drive and hard drive.
Passo 2  ¶
  • Remove the 4 10mm torx screws attatched to the drive carrier.
  • The drive carrier includes optical drive and hard drive.
Passo 3  ¶
Grasp the carrier with both hands on each side.
Passo 3  ¶
  • Grasp the carrier with both hands on each side.
  • Remove the carrier by lifting up and out.
  • Pull gently but firmly. The carrier is meant to fit snugly.
Passo 4  ¶
Flip the removed carrier to the right and pull out power cables.
Passo 4  ¶
  • Flip the removed carrier to the right and pull out power cables.
