Pular para o conteúdo principal
Ajuda
Netgear WGR614v9 Capacitor Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
Repairing the the capacitor will eliminate unwanted buzzing noises.
This guide will take you through the process involved with removing a capacitor. De-soldering and soldering will be required.
Passo 1 Capacitor  ¶
Rotate the motherboard so that the top is facing up. Set the motherboard on a flat clean surface.
Passo 1 Capacitor  ¶
  • Rotate the motherboard so that the top is facing up.
  • Set the motherboard on a flat clean surface.
Passo 2  ¶
The capacitor can be found at the location shown. The capacitor can be found at the location shown.
Passo 2  ¶
  • The capacitor can be found at the location shown.
Passo 3  ¶
Rotate the motherboard so that the bottom is facing up. Locate the two soldered contacts of the capacitor.
Passo 3  ¶
  • Rotate the motherboard so that the bottom is facing up.
  • Locate the two soldered contacts of the capacitor.
Passo 4  ¶
Rotate the motherboard 180 degrees. Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only. Refer to this link for proper de-soldering and soldering techniques.
Passo 4  ¶
  • Rotate the motherboard 180 degrees.
  • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
  • Refer to this link for proper de-soldering and soldering techniques.
  • Pull the capacitor from the other side of the circuit board once the solder is liquified.
  • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
