Pular para o conteúdo principal
Ajuda
Técnica: Repairing a Nintendo DS that is not charging
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
Repairs not charging fault by replacing or bypassing the EM10 filter.
  • Autor: Knut
  • Tempo estimado: 45 minutos
  • Dificuldade: Moderado
If you have NO charge light on the DSL and the battery doesn't charge, the EM10 power supply filter on the motherboard may be faulty.
This guide will allow you to locate, test and replace the filter.
You will find replacement EM10 Filter's on the internet for a few dollars each.
Removing the EM10 and bypassing it may leave the motherboard unprotected against power supply noise. Remove and bypass at own risk!
Passo 1 Repairing a Nintendo DS that is not charging  ¶
The EM10 charging filter is located next to the power connector on the motherboard.
  • The EM10 charging filter is located next to the power connector on the motherboard.
  • If the filter is missing or obviously broken, move on to STEP 18
  • Use a multimeter to test the EM10 filter - measure the resistance between each of the yellow solder pads, and then between each of the cyan solder pads. If everything is OK you should have close to 0 Ohms between each set of pads. You should NOT have any connection between the cyan pads and yellow pads. If the filter fails either test it needs to be replaced.
Passo 2  ¶
Remove the faulty EM10 filter.  Use a soldering iron to melt the solder and gently lift off the filter with tweezers or pliers, being careful not to pull the copper tracks off the motherboard. A replacement EM10 filter is available HERE  (as at 01/01/12) no doubt other suppliers exist Solder new EM10 filter into place, ensuring correct orientation.  If required, check the new filter with a multimeter to confirm before installing.
Passo 2  ¶
  • Remove the faulty EM10 filter. Use a soldering iron to melt the solder and gently lift off the filter with tweezers or pliers, being careful not to pull the copper tracks off the motherboard.
  • A replacement EM10 filter is available HERE (as at 01/01/12) no doubt other suppliers exist
  • Solder new EM10 filter into place, ensuring correct orientation. If required, check the new filter with a multimeter to confirm before installing.
  • Alternate method - Bridge the solder pads that correspond with each set of pads - yellow to yellow and cyan to cyan
  • Bypassing the EM10 filter may affect the system performance and is not recommended
