Pular para o conteúdo principal
Ajuda
PowerBook G4 Aluminum 15" 1.67 GHz PC Card Cage Replacement
This guide will show you how to remove the PC card cage from the lower case of your PowerBook.
Passo 1 PC Card Cage  ¶
Remove the four Phillips screws from the PC card cage.
  • Remove the four Phillips screws from the PC card cage.
  • The two longer screws go on the right side of the card cage.
Passo 2  ¶
Disconnect the PC card cable from the logic board.
Passo 2  ¶
  • Disconnect the PC card cable from the logic board.
Passo 3  ¶
Lift the PC card cage up and remove it from the computer.
Passo 3  ¶
  • Lift the PC card cage up and remove it from the computer.
  • When replacing the PC card cage, make sure you attach it to the post on the metal eject button.
