Pular para o conteúdo principal
Ajuda
Mac mini Mid 2011 Logic Board Replacement
Completely replace your mini's logic board.
Completely replacing the logic board requires removal of the logic board itself as well as all components attached to it.
Passo 1 Logic Board  ¶
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable up off the logic board.
  • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable up off the logic board.
  • Remove the AirPort/Bluetooth ribbon cable.
Passo 2  ¶
Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. After the RAM chip has popped up, pull it straight out of its socket.
Passo 2  ¶
  • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
Passo 3  ¶
Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
Passo 3  ¶
  • Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
Passo 4  ¶
Remove the following screws securing the heat sink to the logic board:
Passo 4  ¶
  • Remove the following screws securing the heat sink to the logic board:
  • Four 8.6 mm T8 Torx screws
  • One 2.6 mm T6 Torx screw
  • Keep track of the springs held beneath each of the T8 heat sink screws.
Passo 5  ¶
Remove the heat sink from the logic board, minding any cables that may get caught.
Passo 5  ¶
  • Remove the heat sink from the logic board, minding any cables that may get caught.
  • If the heat sink appears to be stuck to the logic board after removing all screws, it may be helpful to use a spudger to separate the two components.
  • If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
  • Logic board remains.
