Pular para o conteúdo principal
Ajuda
PlayStation 3 Super Slim Wi-Fi Antennas Replacement
Trouble with connecting to Wi-Fi? This guide will walk you through replacing your PS3's Wi-Fi antennas.
  • Autor: Joseph O'Connor
  • Tempo estimado: 25 - 30 minutos
  • Dificuldade: Moderado
This guide will show the users how to remove the Wi-Fi antennas of the PlayStation 3 Super Slim. The step will show users how to remove the mounted antennas. After, the guide will go into the removal of the antennas' wires from the sockets on the motherboard.
Passo 1 Wi-Fi Antennas  ¶
Locate the white flex ribbon cable that connects the power button to the motherboard. Pull this cable out from the motherboard end. Remove the five black 8.3mm long screws with a Phillips #1 screwdriver. Remove the two silver 12.8mm long screws with a Phillips #1 screwdriver.
  • Locate the white flex ribbon cable that connects the power button to the motherboard. Pull this cable out from the motherboard end.
  • Remove the five black 8.3mm long screws with a Phillips #1 screwdriver.
  • Remove the two silver 12.8mm long screws with a Phillips #1 screwdriver.
  • Remove the device from the bottom shell casing.
Passo 2  ¶
Remove the two black 8.3mm long screws with a Phillips #1 screwdriver from the Wi-Fi antennas. Lift the Wi-Fi antennas off their mount. Lift the Wi-Fi antennas off their mount.
Passo 2  ¶
  • Remove the two black 8.3mm long screws with a Phillips #1 screwdriver from the Wi-Fi antennas.
  • Lift the Wi-Fi antennas off their mount.
Passo 3  ¶
Use a plastic opening tool to remove the Wi-Fi wires from their sockets on the motherboard. Remove the wires from the hooks around the motherboard and fan cover to completely remove the antennas. The Wi-Fi antennas' ports are labeled B and W on the motherboard for reassembly.
Passo 3  ¶
  • Use a plastic opening tool to remove the Wi-Fi wires from their sockets on the motherboard.
  • Remove the wires from the hooks around the motherboard and fan cover to completely remove the antennas.
  • The Wi-Fi antennas' ports are labeled B and W on the motherboard for reassembly.
  • To insert your new Wi-Fi antennas, insert the wires of your replacement Wi-Fi antennas into each socket, feed the wires through the hooks, and install the antennas on their mount.
