Pular para o conteúdo principal
Ajuda
Sony Walkman WM-4 Teardown
Teardown
Teardown
As desmontagens servem para mostrar o que tem dentro de um/uma device e não devem ser usadas como instruções de procedimento.
Balas!
Balas!
Melhor coordenação com marcas e cor/tipo de balas ajudará a tornar mais claro este guia!
Ferramentas incorretas
Ajude a fazer melhor este guia usando as ferramentas corretas em imagens e/ou texto.
Faltou uma etapa
Faltou uma etapa
Ops! Este guia está faltando alguns passos importantes.
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
Before the introduction of MP3 players, people bought their own music. Sony Walkman WM-4 is a second generation cassette player, which was highly popular during this time. This guide tells you how to open a Sony Walkman WM-4.
Passo 1 Sony Walkman WM-4 Teardown  ¶
Flip the Sony Walkman so that its rear side faces you. Use a screwdriver to remove the two screws from the surface of the Walkman.
  • Flip the Sony Walkman so that its rear side faces you.
  • Use a screwdriver to remove the two screws from the surface of the Walkman.
  • Both the screws are highlighted in red in the image.
  • Press the battery plate slightly with your thumb and slide it downwards. This will open the battery compartment.
  • The battery compartment is highlighted in blue in the image.
  • Remove the batteries from the Walkman.
Passo 2  ¶
Turn over your Walkman and gently press the cover to open the cassette holder. When the cassette holder is opened, you can see two more screws.
Passo 2  ¶
  • Turn over your Walkman and gently press the cover to open the cassette holder.
  • When the cassette holder is opened, you can see two more screws.
  • The two screws are highlighted in red in the image.
  • Using a screwdriver, remove the two screws.
Passo 3  ¶
Use a plastic opening tool or a spudger to push the tabs. This will remove the cover and open the Walkman. The tabs are highlighted in blue in the image.
Passo 3  ¶
  • Use a plastic opening tool or a spudger to push the tabs. This will remove the cover and open the Walkman.
  • The tabs are highlighted in blue in the image.
  • Once the Walkman is opened, you can troubleshoot for any issues, remove the old wires and attach new ones, or even reassemble the Walkman.
