Pular para o conteúdo principal
Ajuda
Nintendo 3DS Volume Switch Replacement
Nintendo 3DS volume switch replacement
Can't hear anything through your speakers? Even worse, are they stuck on full volume? You might need a new volume switch.
Passo 1 Volume Switch  ¶
Use the flat end of a spudger to pry the volume switch connector out of its socket on the motherboard. Use the flat end of a spudger to pry the volume switch connector out of its socket on the motherboard.
  • Use the flat end of a spudger to pry the volume switch connector out of its socket on the motherboard.
Passo 2  ¶
Remove the volume switch from the motherboard.
Passo 2  ¶
  • Remove the volume switch from the motherboard.
