Pular para o conteúdo principal
Ajuda
PowerBook G3 Wallstreet RAM Replacement
Replace the RAM in your PowerBook G3 Wallstreet.
  • Autor: iRobot
  • Dificuldade: Fácil
Two RAM slots allow up to 512 MB of PC100 RAM.
Seções
Arquivos
Ferramentas
Passo 1 RAM  ¶
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. There is a similar RAM slot located on the other side of the processor.
Passo 1 RAM  ¶
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up. There is a similar RAM slot located on the other side of the processor.
  • We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor. Accessing RAM in the upper slot merely requires removing the heat shield.
