Pular para o conteúdo principal
Ajuda
HTC Excalibur Keyboard Replacement
Balas!
Balas!
Melhor coordenação com marcas e cor/tipo de balas ajudará a tornar mais claro este guia!
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
Replacing a broken or unresponsive HTC EXCA100 Keyboard
  • Autor: Ian Mitchell
  • Tempo estimado: 20 minutos
  • Dificuldade: Moderado
Seções
Ferramentas
Ferramentas (continuação)
Partes relevantes
Passo 1 Keyboard  ¶
Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
Passo 1 Keyboard  ¶
  • Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
Passo 2  ¶
Remove the metal backing to the keyboard using Phillip 00 screwdriver to remove the 3 screws. After the screws are removed, take off the back cover of the keyboard. You can now peel off the keyboard, and replace it. After the new keyboard is in place, reassemble the device.
Passo 2  ¶
  • Remove the metal backing to the keyboard using Phillip 00 screwdriver to remove the 3 screws.
  • After the screws are removed, take off the back cover of the keyboard.
  • You can now peel off the keyboard, and replace it. After the new keyboard is in place, reassemble the device.
