Pular para o conteúdo principal
Ajuda
Nikon N2000 (F301) Battery Compartment Replacement
Fotos de ação
Fotos de ação
Seja um herói em ação! Este guia precisa de imagens que melhor demonstrem como executar ações específicas.
Imagens inconsistentes
Atualizar as imagens deste guia para ser mais consistente com os pré-requisitos aumentaria a sua grandiosidade.
Pré-requisitos incompatíveis
Este guia não tem um guia de pré-requisito adequado. Ajude a combinar com o seu parceiro ideal encontrando-o ou escreva um!
Pré-requisitos ausentes
Este guia está faltando informações sobre como começar. Faça um guia de início!
How to remove the Battery compartment for cleaning, testing, or replacement.
If there is a power problem, you may need to reattach wires to the battery compartment or replace it completely. If the problem is Corrosion, just see the guide on corrosion.
Passo 1 Battery Compartment  ¶
Sem imagem
  • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
  • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
Passo 2  ¶
Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
Passo 2  ¶
  • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
Passo 3  ¶
Pull up on the tab to remove the batteries.
Passo 3  ¶
  • Pull up on the tab to remove the batteries.
  • Note: The batteries will probably fall out of their holder.
Passo 4  ¶
Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
Passo 4  ¶
  • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
Passo 5  ¶
Remove the battery compartment from the camera.
Passo 5  ¶
  • Remove the battery compartment from the camera.
  • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
