Pular para o conteúdo principal
Ajuda
Dell Inspiron 5100 PP07L Screen Replacement
Polícia gramatical
Polícia gramatical
Abrace seu professor de Inglês interior e ajude a melhorar a gramática deste guia!
Pré-requisitos ausentes
Este guia está faltando informações sobre como começar. Faça um guia de início!
Texto confuso
Texto confuso
Alguns dos textos deste guia é confuso, duplicado ou fora-tópico. Melhore-o!
Your screen does not display anything, but you can hear your computer running. Your screen cable may be unplugged or damaged, and you need to replace it.
You will be able to access wires connecting your screen and replace it if needed.
Seções
Ferramentas
Passo 1 Screen  ¶
Remove two screws (5.8mm) located at the rear of the laptop. Remove two screws (5.8mm) located at the rear of the laptop.
Passo 1 Screen  ¶
  • Remove two screws (5.8mm) located at the rear of the laptop.
Passo 2  ¶
Detach screen connector.
Passo 2  ¶
  • Detach screen connector.
Passo 3  ¶
Remove four screws (5.8 mm) located at hinges of the screen. Remove four screws (5.8 mm) located at hinges of the screen.
Passo 3  ¶
  • Remove four screws (5.8 mm) located at hinges of the screen.
Passo 4  ¶
Lift and remove display screen.
Passo 4  ¶
  • Lift and remove display screen.
