Pular para o conteúdo principal
Ajuda
iPhone 6s Cellular Antenna Replacement
Replace the upper left antenna in an iPhone 6s.
  • Autor: Evan Noronha
  • Tempo estimado: 30 minutos - 1 hora
  • Dificuldade: Moderado
Follow the steps in this guide to replace the upper left antenna in an iPhone 6s.
Passo 1 Cellular Antenna  ¶
Remove the two 2.3 mm Phillips screws over the audio control cable bracket. Remove the audio control cable bracket. Remove the audio control cable bracket.
  • Remove the two 2.3 mm Phillips screws over the audio control cable bracket.
  • Remove the audio control cable bracket.
Passo 2  ¶
Remove the following five Phillips screws holding the antenna in place: Two 1.5 mm screws
Passo 2  ¶
  • Remove the following five Phillips screws holding the antenna in place:
  • Two 1.5 mm screws
  • One 2.3 mm screw
  • Two 2.0 mm screws set into the top edge of the rear case
Passo 3  ¶
Remove the upper left antenna. Remove the upper left antenna.
Passo 3  ¶
  • Remove the upper left antenna.
