Pular para o conteúdo principal
Ajuda
Nokia E61i Display Replacement
Texto confuso
Texto confuso
Alguns dos textos deste guia é confuso, duplicado ou fora-tópico. Melhore-o!
Faltou uma etapa
Faltou uma etapa
Ops! Este guia está faltando alguns passos importantes.
Fotos de ação
Fotos de ação
Seja um herói em ação! Este guia precisa de imagens que melhor demonstrem como executar ações específicas.
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
Remove the LCD from your Nokia E61i for replacement
Use this guide to replace the Nokia E61i screen.
Passo 1 Display  ¶
After casing and keyboard have been taken off, remove the screws holding the screen in place using a T-6 for the screws in the middle of the red circles and a T-5 for the screw in the middle of the red square. Lift ribbon off of the contact with the logic board
Passo 1 Display  ¶
  • After casing and keyboard have been taken off, remove the screws holding the screen in place using a T-6 for the screws in the middle of the red circles and a T-5 for the screw in the middle of the red square.
  • Lift ribbon off of the contact with the logic board
  • *When reassembling, make sure to firmly press contacts into place to ensure a connection is made between ribbon and logic board
Passo 2  ¶
Once the screws are out, gently pull the screen off of the phone. *NOTICE* The sticker that attaches the display (in the middle of the blue square again) and the logic board is to be removed safely and be sure not to rip this apart. Finally, pull the silver case off to completely free the cracked or damaged screen.
Passo 2  ¶
  • Once the screws are out, gently pull the screen off of the phone. *NOTICE* The sticker that attaches the display (in the middle of the blue square again) and the logic board is to be removed safely and be sure not to rip this apart.
  • Finally, pull the silver case off to completely free the cracked or damaged screen.
