Pular para o conteúdo principal
Ajuda
HP PSC 2410 Photosmart All In One Printer Scanner Lamp Replacement
Fotos de ação
Fotos de ação
Seja um herói em ação! Este guia precisa de imagens que melhor demonstrem como executar ações específicas.
Replace the scanner lamp on your printer's scanner.
If your scanner is not working, odds are that your scanner lamp is burned out and needs to be replaced. In order to replace the scanner lamp, the scanner tray and glass must be removed from the printer.
Note: The scanner lamp is very fragile and must be handled with care.
Seções
Ferramentas
Partes relevantes
Passo 1 Scanner Lamp  ¶
Remove the scanner head from the scanner tray by lifting the scanner head up and pulling the black tab from the gray drive belt.
  • Remove the scanner head from the scanner tray by lifting the scanner head up and pulling the black tab from the gray drive belt.
Passo 2  ¶
Turn the scanner upside down and place it on a level surface. Remove the small silver screw in the scanner head's control panel.
Passo 2  ¶
  • Turn the scanner upside down and place it on a level surface.
  • Remove the small silver screw in the scanner head's control panel.
Passo 3  ¶
Remove the control panel from the scanner head.
Passo 3  ¶
  • Remove the control panel from the scanner head.
Passo 4  ¶
Remove the black face plate from the scanner head. Push on the two black tabs located on opposite sides of the scanner head. One of them is located in the groove the control panel normally rests in. Remove the black face plate from the scanner head. Push on the two black tabs located on opposite sides of the scanner head. One of them is located in the groove the control panel normally rests in. Remove the black face plate from the scanner head. Push on the two black tabs located on opposite sides of the scanner head. One of them is located in the groove the control panel normally rests in.
Passo 4  ¶
  • Remove the black face plate from the scanner head. Push on the two black tabs located on opposite sides of the scanner head. One of them is located in the groove the control panel normally rests in.
Passo 5  ¶
Carefully twist white scanner lamp support out of its carriage and replace it with a new one. Note:  Scanner lamps are fragile and should be handled with care.
Passo 5  ¶
  • Carefully twist white scanner lamp support out of its carriage and replace it with a new one.
  • Note: Scanner lamps are fragile and should be handled with care.
