Pular para o conteúdo principal
Ajuda
Samsung Eternity Motherboard Replacement
Balas!
Balas!
Melhor coordenação com marcas e cor/tipo de balas ajudará a tornar mais claro este guia!
This guide will show you step-by-step instructions on how to remove the motherboard from the phone to replace it with a new one.
  • Autor: Kevin Huang
  • Tempo estimado: 15 - 25 minutos
  • Dificuldade: Moderado
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's motherboard.
Passo 1 Motherboard  ¶
It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
  • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
  • Pull the antenna plug out of its socket.
Passo 2  ¶
Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out. Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out. Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Passo 2  ¶
  • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Passo 3  ¶
Pop the red hinged-release lever away from its ribbon. Then pull it out.
Passo 3  ¶
  • Pop the red hinged-release lever away from its ribbon. Then pull it out.
Passo 4  ¶
Peel the button sensor on the side of the motherboard off of the case.
Passo 4  ¶
  • Peel the button sensor on the side of the motherboard off of the case.
Passo 5  ¶
Slightly pull up one side of the motherboard. Pull the button/microphone plug out of its socket. Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
Passo 5  ¶
  • Slightly pull up one side of the motherboard.
  • Pull the button/microphone plug out of its socket.
  • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
Passo 6  ¶
You have successfully removed the motherboard from the phone.
Passo 6  ¶
  • You have successfully removed the motherboard from the phone.
