Pular para o conteúdo principal
Ajuda
HP Pavilion zd8000 Keyboard Replacement
  • Autor: Allie Menard
  • Tempo estimado: 4 minutos
  • Dificuldade: Moderado
Removing your keyboard takes a few simple steps.
Seções
Ferramentas
Passo 1 Keyboard  ¶
Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
Passo 1 Keyboard  ¶
  • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
Passo 2  ¶
Flip the laptop over and open the screen. Push up on the four latches located at the top of the keyboard with the spudger to release them.
Passo 2  ¶
  • Flip the laptop over and open the screen.
  • Push up on the four latches located at the top of the keyboard with the spudger to release them.
Passo 3  ¶
Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable. Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
Passo 3  ¶
  • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
  • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
Passo 4  ¶
Rotate the keyboard so that the bottom is visible. With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
Passo 4  ¶
  • Rotate the keyboard so that the bottom is visible.
  • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
  • Pull the tab towards you to release the keyboard from the laptop.
