Pular para o conteúdo principal
Ajuda
Canon EOS A2 Top Cover Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
Removing top cover of camera to give access to LCD screen, control dial, and flash.
  • Autor: Mark
  • Dificuldade: Moderado
Removing the top cover of camera gives access to the LCD screen, control dial, and flash.
Passo 1 Top Cover  ¶
Remove the 4.3mm screw below the camera strap ring.
Passo 1 Top Cover  ¶
  • Remove the 4.3mm screw below the camera strap ring.
Passo 2  ¶
Remove two 4.8mm screws located on both sides of the eyepiece.
Passo 2  ¶
  • Remove two 4.8mm screws located on both sides of the eyepiece.
Passo 3  ¶
Pull the top cover up slowly.
Passo 3  ¶
  • Pull the top cover up slowly.
  • A ribbon cable is attached to the bottom of the top cover and the camera. Pull up very carefully to avoid damaging this.
Passo 4  ¶
Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
Passo 4  ¶
  • Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
  • If you pull the white tabs all the way out, just insert them back in to avoid losing them.
