Pular para o conteúdo principal
Ajuda
Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement
This guide will aid you in removing the CD/DVD Drive from the system.
  • Autor: Michael Jensen
  • Tempo estimado: 5 minutos
  • Dificuldade: Moderado
Passo 1 CD/DVD Drive  ¶
Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
Passo 2  ¶
Locate and remove the circled screw with a Phillips #0 screwdriver. Locate and remove the circled screw with a Phillips #0 screwdriver.
Passo 2  ¶
  • Locate and remove the circled screw with a Phillips #0 screwdriver.
Passo 3  ¶
Use the plastic opening tool to pry the CD/DVD drive out of the frame.
Passo 3  ¶
  • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
Passo 4  ¶
Gently remove the CD/DVD drive from the laptop body.
Passo 4  ¶
  • Gently remove the CD/DVD drive from the laptop body.
