Pular para o conteúdo principal
Ajuda
iPad 2 Wi-Fi EMC 2415 Bluetooth/Wi-Fi Antenna Replacement
Replace a broken antenna in your iPad 2 Wi-Fi EMC 2415.
  • Autor: Andrew Bookholt
  • Tempo estimado: 2 - 4 horas
  • Dificuldade: Muito difícil
Use this guide to replace a broken antenna.
Passo 1 Bluetooth/Wi-Fi Antenna  ¶
Move the dock connector/speaker cables out of the way and peel the Bluetooth/Wi-Fi antenna cable off the adhesive securing it to the rear case.
  • Move the dock connector/speaker cables out of the way and peel the Bluetooth/Wi-Fi antenna cable off the adhesive securing it to the rear case.
Passo 2  ¶
Remove the following screws securing the Bluetooth/Wi-Fi antenna to the rear case:
Passo 2  ¶
  • Remove the following screws securing the Bluetooth/Wi-Fi antenna to the rear case:
  • Two 1.7 mm Phillips screws
  • Two 2.0 mm Phillips screws
Passo 3  ¶
Peel the Bluetooth/Wi-Fi antenna off the speaker enclosure and remove it from the iPad 2.
Passo 3  ¶
  • Peel the Bluetooth/Wi-Fi antenna off the speaker enclosure and remove it from the iPad 2.
