Pular para o conteúdo principal
Ajuda
HP Pavilion dv1000 RAM Replacement
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
Melhor Introdução
Melhor Introdução
Melhore este guia, completando ou revendo a sua introdução.
This guide covers the steps required to access the RAM of the HP Pavilion dv1000.
  • Autor: Henry OBrien
  • Tempo estimado: 15 minutos
  • Dificuldade: Fácil
Seções
Ferramentas
Partes relevantes
Passo 1 RAM  ¶
Locate RAM access door on the bottom side of the laptop.
Passo 1 RAM  ¶
  • Locate RAM access door on the bottom side of the laptop.
Passo 2  ¶
Locate the two screws holding down the RAM access cover Unscrew the two screws with a size 00 Philips screwdriver. Note: The screws do not detach from the cover.
Passo 2  ¶
  • Locate the two screws holding down the RAM access cover
  • Unscrew the two screws with a size 00 Philips screwdriver.
  • Note: The screws do not detach from the cover.
Passo 3  ¶
Lift up on the screw side of the RAM access cover to remove it. Lift up on the screw side of the RAM access cover to remove it.
Passo 3  ¶
  • Lift up on the screw side of the RAM access cover to remove it.
Passo 4  ¶
Gently pull apart the metal tabs located on both sides of the stick of RAM. The RAM stick should tilt upwards.
Passo 4  ¶
  • Gently pull apart the metal tabs located on both sides of the stick of RAM.
  • The RAM stick should tilt upwards.
Passo 5  ¶
Gently lift the the RAM up and out of its seat.
Passo 5  ¶
  • Gently lift the the RAM up and out of its seat.
Passo 6  ¶
Repeat the previous two steps for the remaining stick of RAM.
Passo 6  ¶
  • Repeat the previous two steps for the remaining stick of RAM.
