Pular para o conteúdo principal
Ajuda
iMac Intel 24" EMC 2111 Inverter Board Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
Replace the inverter board on your iMac Intel 24" EMC 2111.
Having display backlight issues? Use this guide to replace a blown inverter board.
Passo 1 Inverter Board  ¶
Peel the strip of foam tape off the inverter board.
  • Peel the strip of foam tape off the inverter board.
Passo 2  ¶
Remove the large piece of black tape covering the side of the inverter board.
Passo 2  ¶
  • Remove the large piece of black tape covering the side of the inverter board.
Passo 3  ¶
Remove the two Phillips screws securing the inverter board to the back of the LCD.
Passo 3  ¶
  • Remove the two Phillips screws securing the inverter board to the back of the LCD.
Passo 4  ¶
Carefully lift the black cover off the inverter board from the side closest to the edge of the LCD.
Passo 4  ¶
  • Carefully lift the black cover off the inverter board from the side closest to the edge of the LCD.
  • Disconnect the seven locking connectors from the side of the inverter board.
Passo 5  ¶
Lift the inverter board off the LCD. When reinstalling the inverter board, be sure to push the board under the two tabs nearest the center of the LCD before lowering it down into place.
Passo 5  ¶
  • Lift the inverter board off the LCD.
  • When reinstalling the inverter board, be sure to push the board under the two tabs nearest the center of the LCD before lowering it down into place.
