Pular para o conteúdo principal
Ajuda
Casio Exilim EX-Z850 Flash Assembly Replacement
Balas!
Balas!
Melhor coordenação com marcas e cor/tipo de balas ajudará a tornar mais claro este guia!
Texto confuso
Texto confuso
Alguns dos textos deste guia é confuso, duplicado ou fora-tópico. Melhore-o!
Melhor Introdução
Melhor Introdução
Melhore este guia, completando ou revendo a sua introdução.
Faltando detalhes
Faltando detalhes
Alguns dos detalhes deste guia estão faltando. Ajude os usuários adicionando ferramentas, dificuldades, ou tempo.
How to replace flash assembly
Passo 1 Flash Assembly  ¶
Remove the four screws on the side of the speaker.
  • Remove the four screws on the side of the speaker.
Passo 2  ¶
Remove the two back screws on the bottom of the camera.
Passo 2  ¶
  • Remove the two back screws on the bottom of the camera.
  • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
Passo 3  ¶
Remove the four screws on the side opposite of the speaker.
Passo 3  ¶
  • Remove the four screws on the side opposite of the speaker.
Passo 4  ¶
Once all screws have been removed, gently pry open bottom casing. With tweezers, carefully remove ribbon from LCD screen.
Passo 4  ¶
  • Once all screws have been removed, gently pry open bottom casing.
  • With tweezers, carefully remove ribbon from LCD screen.
  • Set bottom casing aside.
Passo 5  ¶
Gently pry apart the top casing using tweezers. Set the top casing aside. Set the top casing aside.
Passo 5  ¶
  • Gently pry apart the top casing using tweezers.
  • Set the top casing aside.
Passo 6  ¶
Use tweezers or prongs to pry the LCD screen off from the opening. Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
Passo 6  ¶
  • Use tweezers or prongs to pry the LCD screen off from the opening.
  • Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
Passo 7  ¶
Lift up the LCD screen, slowly move it to the other side. Lift up the LCD screen, slowly move it to the other side.
Passo 7  ¶
  • Lift up the LCD screen, slowly move it to the other side.
Passo 8  ¶
Pry off the LCD casing. Pry off the LCD casing.
Passo 8  ¶
  • Pry off the LCD casing.
Passo 9  ¶
Flip open the connector holding the ribbon. Pull out the LCD screen with the ribbon from the camera. Pull out the LCD screen with the ribbon from the camera.
Passo 9  ¶
  • Flip open the connector holding the ribbon.
  • Pull out the LCD screen with the ribbon from the camera.
Passo 10  ¶
Remove two screws on the side where the battery is located. Remove the lanyard loop after the screws come off.
Passo 10  ¶
  • Remove two screws on the side where the battery is located.
  • Remove the lanyard loop after the screws come off.
  • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
Passo 11  ¶
On the front of the camera near the flash flip the connector holding the ribbon. Remove the ribbon from the connector.
Passo 11  ¶
  • On the front of the camera near the flash flip the connector holding the ribbon.
  • Remove the ribbon from the connector.
Passo 12  ¶
Carefully remove the L shaped frame from the camera. At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab. Pop the frame off the bumps and tabs.
Passo 12  ¶
  • Carefully remove the L shaped frame from the camera.
  • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
  • Pop the frame off the bumps and tabs.
  • Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
Passo 13  ¶
This is the flash assembly. It needs to be removed with soldering points circled.
Passo 13  ¶
  • This is the flash assembly.
  • It needs to be removed with soldering points circled.
