Pular para o conteúdo principal
Ajuda
Sharp Aquos LC13B2UA Speakers Replacement
Polícia gramatical
Polícia gramatical
Abrace seu professor de Inglês interior e ajude a melhorar a gramática deste guia!
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
Give a short summary.
Outline what you are going to teach someone how to do.
Seções
Ferramentas
Passo 1 Speakers  ¶
Remove the eight 9mm screws from both speakers. DO NOT remove speakers yet - they are still attached.
Passo 1 Speakers  ¶
  • Remove the eight 9mm screws from both speakers.
  • DO NOT remove speakers yet - they are still attached.
Passo 2  ¶
Remove the two speaker cables from the circuit board by pinching the plastic connectors and firmly pulling up. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
Passo 2  ¶
  • Remove the two speaker cables from the circuit board by pinching the plastic connectors and firmly pulling up.
  • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
Passo 3  ¶
Remove the two black tape strips (one on each side) securing the power cable to the frame. The speakers can now be removed.
Passo 3  ¶
  • Remove the two black tape strips (one on each side) securing the power cable to the frame.
  • The speakers can now be removed.
