Pular para o conteúdo principal
Ajuda
MacBook Air 13" Late 2010 Right Speaker Replacement
Replace a blown right speaker in youMacBook Air 13" Late 2010.
Use this guide to replace a blown-out right speaker.
Ferramentas (continuação)
Partes relevantes
Passo 1 Right Speaker  ¶
Remove the single 2.7 mm T5 Torx screw securing the right speaker to the upper case.
  • Remove the single 2.7 mm T5 Torx screw securing the right speaker to the upper case.
Passo 2  ¶
Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
Passo 2  ¶
  • Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
  • Pry up from beneath the wires.
Passo 3  ¶
Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case. Remove the right speaker from the upper case.
Passo 3  ¶
  • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
  • Remove the right speaker from the upper case.
