Pular para o conteúdo principal
Ajuda
HP Mini 1000 Keyboard Replacement
Replace the keyboard in your HP Mini 1000.
  • Autor: Walter Galan
  • Tempo estimado: 15 - 30 minutos
  • Dificuldade: Moderado
Seções
Ferramentas
Passo 1 Keyboard  ¶
Remove the following two screws:
Passo 1 Keyboard  ¶
  • Remove the following two screws:
  • One 6 mm Phillips screw
  • One 4 mm Phillips screw
Passo 2  ¶
To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000. While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you. Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
Passo 2  ¶
  • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
  • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
  • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
Passo 3  ¶
Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
Passo 3  ¶
  • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
Passo 4  ¶
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
Passo 4  ¶
  • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
  • Be sure you are prying up on the retaining flap, not the socket itself.
  • Pull the cable out of its socket and remove the keyboard.
