Pular para o conteúdo principal
Ajuda
Sega CD CD Tray Replacement
Melhor Introdução
Melhor Introdução
Melhore este guia, completando ou revendo a sua introdução.
This guide will show how to remove the CD tray from your console.
  • Autor: sskyllin
  • Tempo estimado: 15 - 30 minutos
  • Dificuldade: Moderado
Passo 1 CD Tray  ¶
Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate. The three screws are shown on the diagram.
Passo 1 CD Tray  ¶
  • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
  • The three screws are shown on the diagram.
Passo 2  ¶
Remove the two screws from the plastic bar. The two screws are shown pictured.
Passo 2  ¶
  • Remove the two screws from the plastic bar.
  • The two screws are shown pictured.
Passo 3  ¶
To remove the CD tray Remove the four screws with the Phillips head screwdriver.
Passo 3  ¶
  • To remove the CD tray
  • Remove the four screws with the Phillips head screwdriver.
Passo 4  ¶
Carefully unplug the wire connected to optical reader.
Passo 4  ¶
  • Carefully unplug the wire connected to optical reader.
Passo 5  ¶
Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver. The four screws are highlighted on the diagram.
Passo 5  ¶
  • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
  • The four screws are highlighted on the diagram.
  • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
Passo 6  ¶
Carefully remove the CD tray from circuit board.
Passo 6  ¶
  • Carefully remove the CD tray from circuit board.
