Pular para o conteúdo principal
Ajuda
Técnica: How to clean Apple Mighty Mouse scroll ball
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
Clean the scrollball without opening up the mouse.
  • Autor: bushing
  • Tempo estimado: 10 minutos
  • Dificuldade: Muito fácil
Before taking any more drastic measures, you should try simply cleaning a misbehaving scrollball from outside the mouse.
Passo 1 How to clean Apple Mighty Mouse scroll ball  ¶
Before you continue, turn off the mouse using the slide switch underneath the mouse.
  • Before you continue, turn off the mouse using the slide switch underneath the mouse.
  • Before disassembling the mouse, first try scrubbing the mouse ball with a toothbrush and isopropyl alcohol. Be sure to get the bristles between the ball and the housing as this will help remove dirt and dust that is clogging the rollers inside.
  • You can also try blowing into the "ball hole" with a can of compressed air.
