Pular para o conteúdo principal
Ajuda
HP Pavilion dv5000 Optical Drive Replacement
Removing the optical drive
  • Autor: Alex Kwok
  • Tempo estimado: 10 - 15 minutos
  • Dificuldade: Fácil
This guide will tell you how to remove the optical drive, or CD/DVD drive.
Seções
Ferramentas
Passo 1 Optical Drive  ¶
Remove the 11.0mm screw securing the optical drive to the computer.
  • Remove the 11.0mm screw securing the optical drive to the computer.
Passo 2  ¶
Locate the optical drive. The optical drive is located on the left side of the RAM bay. Press the exposed edge of the optical drive gently with the spudger until the drive releases from the computer frame. Pull the optical drive completely out of the computer frame.
Passo 2  ¶
  • Locate the optical drive. The optical drive is located on the left side of the RAM bay.
  • Press the exposed edge of the optical drive gently with the spudger until the drive releases from the computer frame.
  • Pull the optical drive completely out of the computer frame.
