Pular para o conteúdo principal
Ajuda
Nintendo DSi Power Board Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
Replace the power board on your Nintendo DSi.
Use this guide to replace your DSi's power board. Replacing the power board will give you a new battery connector and new electronic switches for the D-pad as well as the power button.
Passo 1 Power Board  ¶
Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
Passo 2  ¶
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on power board ZIF connector. Be sure you are prying up on the hinged retaining flap, not the socket itself.
Passo 2  ¶
  • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on power board ZIF connector.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • After flipping up the locking tab on the socket, use your fingers or a pair of tweezers to gently pull the cable straight out of its socket.
Passo 3  ¶
Remove the five 2.6 mm Phillips screws securing the power board to the DSi's framework. Lift and remove the power board out of the DSi.
Passo 3  ¶
  • Remove the five 2.6 mm Phillips screws securing the power board to the DSi's framework.
  • Lift and remove the power board out of the DSi.
Passo 4  ¶
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on LED indicator ZIF connector. Be sure you are prying up on the hinged retaining flap, not the socket itself.
Passo 4  ¶
  • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on LED indicator ZIF connector.
  • If necessary, transfer the power board ribbon cable to your new power board.
