Pular para o conteúdo principal
Ajuda
Sony Cyber-shot DSC-W55 Back Case Replacement
Disassembling the back cover of the camera so that we can repair components from the inside.
  • Autor: kkfong91
  • Tempo estimado: 5 minutos
  • Dificuldade: Fácil
Passo 1 Back Case  ¶
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel. Remove that panel.
Passo 1 Back Case  ¶
  • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
  • Remove that panel.
  • Careful for falling pieces.
Passo 2  ¶
Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel). Remove that panel.
Passo 2  ¶
  • Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
Passo 3  ¶
Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
Passo 3  ¶
  • Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
Passo 4  ¶
Gently remove the back cover. It may be a bit stiff, so use some force to remove it. Proceed with caution.
Passo 4  ¶
  • Gently remove the back cover.
  • It may be a bit stiff, so use some force to remove it. Proceed with caution.
