Pular para o conteúdo principal
Ajuda
Acer Aspire One ZG5 Keyboard Replacement
This guide will show you how to install a new keyboard.
  • Autor: Doug Gallatin
  • Tempo estimado: 5 minutos
  • Dificuldade: Moderado
It is very straight-forward install a new keyboard; only three tabs and a cable hold it in place.
Seções
Ferramentas
Passo 1 Keyboard  ¶
Turn the netbook over and open the display so that the keyboard is facing you.
Passo 1 Keyboard  ¶
  • Turn the netbook over and open the display so that the keyboard is facing you.
Passo 2  ¶
There are three tabs located on the top of the keyboard. Start with the spudger pointing towards the display and pry up to push each tab off the keyboard. As you move to the next tab, ensure the previous tab doesn't reset itself.
Passo 2  ¶
  • There are three tabs located on the top of the keyboard.
  • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
  • As you move to the next tab, ensure the previous tab doesn't reset itself.
Passo 3  ¶
Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side. There is a short ribbon cable connecting the keyboard to the netbook.
Passo 3  ¶
  • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
  • There is a short ribbon cable connecting the keyboard to the netbook.
Passo 4  ¶
Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable. Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
Passo 4  ¶
  • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
